I am trying to globally edit the GEOPAK D & C Manager database (ddb) in order to change the font used by all of the entries to a TrueType font. I saved the ddb as a txt file in order to do a "search and replace" on the font name. However I can find no reference to fonts anywhere in the txt version of the ddb. How can I accomplish this global edit?
FWIW, I successfully followed the above procedure to edit the smd database to change the font of every survey feature.
Josh MauritzMS V8i SS3GEOPAK V8i SS2
You have to use the Save As Microsoft Access Database option to change the fonts to true type fonts globally.
Thanks. I successfully modified the fonts using your suggestion.
