We are performing intersection survey work and creating tin files for a client, who does not use V8i. They are using Microstation and Geopak V8 2004 versions, while we are running V8i SS2 versions. When trying to load our tin files, they receive an error stating that the tin is an unrecognized version. What would be the easiest way to convert these tin files to the V8 2004 version? Do I need to visualize the triangles into a 3d dgn, open the file using MS and Geopak V8 2004 versions, then extract the graphic triangles as break lines to create a tin which the client can load and use?
Thanks.
You can export XML ... or you can just send them the 3D graphical triangles DGN file and they can create the TIN from that.
Derricke
Derricke,
Can you explain why the TIN files are not compatible?
Neil Wilson (aka Neilw)
Power Civil v8i 08.11.07.245
AutoCAD Civil 3D 2018
