Hello guys
Am working on a design, a 4lane divided highway template with raised median barrier and kerbs together with cover drainage, in which the shoulder and the drainage are together, so i built the template and applied it to the corridor, but when i tried to calculate the superelevation for the curved section, i discovered that while in the superelevation mode my template was not well interpreted by inroads, it was picking templates points that are not needed to define the section of the road to be superelevated, it was picking points that were directly above the required points. it would make alot of sense if i include a picture of my template so you guys can have a look at it.
this is a link to the picture of the template: https://hotfile.com/dl/154152787/d2b0877/SUPERELEVATION_PROBLEMS.jpg.html
Please am currently stucked in this stage, pls any suggestion on the possible way to build templates for divided highway with raised median that includes drain and shoulder, just as i have it in the picture above, and it will be able to calculate the superelevation. what i discorvered is that superelevation wizard will always look for all the top points in a template, but from the template i designed some of my points a directly below. so please how do i solve this problem.
Thanks to the entire house, looking forward to your replies
Thank You,
I have no background with InRoads and Autocad. You must contact Bentley Support for thier advice. If you are going to the BE Conference in Philadelphia, PA USA you will gain alot of knowledge in these areas. I will be there.
Joe
Thanks alot Joe, i would really love to be at the BE conference, but due to the workload in the office, i cannot make it, i know it is going to be an exciting one for you, so please have a wonderful time over there in PA.
Once more thanks alot, you inspire me alot.
AKANDE PAUL
CDSS NIGERIA (ASST PRODUCT MANAGER AND TRAINER)
BENTLEY PARTNER IN NIGERIA
