IR. 566 Import Surface Advanced B-Splines support please!
"Import Surface from Graphics" supports B-splines  why not "Import Surface Advanced" ?
  • Hi Frank,
    This issue are fixed in V08.11.07.536.
    You need only to have correctly import rule defined (level, colorpoint type etc.)
    Asmir
  • I'm using V08.11.07.566 and my rule is correct.
    Types: "curve"    the type i'm assocating with b-spline, only ?!
    Level setting is correct!
    I'm using "Match endpoints" for the "Liniear Features" as Asmir has set "One Linestring per Feature"
    and it does not work!
    And the funny thing "Highlight Matching Elements" on the "Selection Criteria" General Tab does work!
    Frank
    since 1985: GIS, CAD, Engineering (Civil)  Senior Consultant : [Autodesk Civil 3D , Esri ArcGIS, VertiGIS: in previous days : Bentley MS V4 - V8i, GeoGraphics, Bentley Map V8i, InRoads,  HHK Geograf, IBr DAVID] :  Dev: [C, C++, .NET, Java, SQL, FORTRAN, UML]
    [direct quote by: http://en.wikipedia.org/wiki/Helmut_Schmidt]: "Wer Kritik übel nimmt, hat etwas zu verbergen"
    Wer Grammatik- und/oder Rechtschreibfehler findet, der darf sie behalten :-)
