I'm having an issue with overlay components displayed in cross section. The component works as it should in the roadway designer, projecting to the surface at a depth of half an inch. However when I display the generated surface components in cross-sections, the overlay components do not show as being projected to the surface.
Has anyone else run into this issue? Attached is a screen shot of what I'm experiencing.
Thanks in advance for your help.
A defect has been filed for this issue: Defect 131107.
Answer Verified By: Carlos.Lopez
