Roundabouts - InRoads SS2
ALL - How do I "drop" a roundabout to lose its dynamic capabilities so that I may edit individual components as I see fit? I need to provide some radii that are a bit unconventional, so I would like to have manual control. The approaches are pretty well set, so I'm not concerned about losing the dynamic aspect.
THANKS!
Parents Reply Children
  • I never got a good solution to this. Instead, I referenced the roundabout into a new file. Then I was able to copy the elements into that file and drop them. It turned out to be quite a cumbersome process, so once the alignments were relatively set, I quit using the roundabout tool. It also gives you really odd radii on the splitter islands that aren't ideal for constructability or for plan labeling. Good luck with the presentation!
