I am trying to make cross section for median i am getting problem with left side vertical offset , vertical offset is applying for CEL0, for right no problem.
please respond it as soon as possible.
******RIGHT Meadian ************
110,MCL0,3=LCL0,4=0.15,5=8600,7=0,8=23700101,MCL0,2=LCL0,3=LCK2,4=0,5=8600,7=-4,8=11150,10=-4101,MCL0,2=LCL0,3=LCK2,4=0,5=11150,7=-4,8=11370,10=-6101,MCL0,2=LCL0,3=LCK2,4=0,5=11370,7=-6,8=13200,10=-6101,MCL0,2=LCL0,3=LCK2,4=0,5=13200,7=-6,8=13400,10=-8101,MCL0,2=LCL0,3=LCK2,4=0,5=13400,7=-8,8=23700,10=-8110,MCL0,2=LCK2,3=CEL0,4=-0.15,5=8600,7=0,8=23700
110,MCR0,3=LCR0,4=0.15,5=8600,7=0,8=23700101,MCR0,2=LCR0,3=LCK1,4=0,5=8600,7=4,8=11150,10=4
101,MCR0,2=LCR0,3=LCK1,4=0,5=11150,7=4,8=11370,10=6
101,MCR0,2=LCR0,3=LCK1,4=0,5=11370,7=6,8=13200,10=6101,MCR0,2=LCR0,3=LCK1,4=0,5=13200,7=6,8=13400,10=8101,MCR0,2=LCR0,3=LCK1,4=0,5=13400,7=8,8=23700,10=8110,MCR0,2=LCK1,3=CER0,4=-0.15,5=8600,7=0,8=23700
What exactly is your problem? Is it when taking the cross-section of the median?
yes it is problem of cross section at the center-line Right is ploting RCR0 ,0.15 above MCR0 but left is not plotting LCL0 0.15 above MCL0. In fact whatever i am making for LCL0 is applying for CEL0. I tried so many times but always failed.
Sreenivas
Mark Marnell.
i have you find that is problem.
When taking cross-sections, you should not have vertical faces i.e. strings should not be in the same plan position with different levels. This also is true when triangulatiing a surface - no vertical faces allowed.
Ensure your strings have a 2mm horizontal offset - you may be just getting lucky with the right median, but it should have an offset.
Thank your reply Mr. Mark Marnell
OK agreed but i got one time i made it by above line mode it is possible only. when i am making next time there is a problem. I will not leave this here i will try to make it . Please you try you may get it.
sreenivasbachu
