Hey,
I have Geopak Suite 8.11.07.566 installed, along with Inroads Suite 8.11.07.566 using Microstation version 8.11.07.443
Recently i've been unable to open Geopak using the icon with -wsLoad_GEOPAK_SS2=1 attached. It opens up vanilla microstation with a text window with the following:
MDL Loader: Could not load application Bentley.InRoads.Commands.AT.dllOS could not load C:\Program Files (x86)\Bentley\InRoads Group V8.11\bin\gpkDgnAT.2.0.dll, error 126.MDL Loader: Unable to load library (DLL or MDL shared library) gpkDgnAT.2.0.dllOS could not load C:\Program Files (x86)\Bentley\InRoads Group V8.11\bin\gpkdgnAT.2.0.dll, error 126.MDL Loader: Unable to load library (DLL or MDL shared library) gpkdgnAT.2.0OS could not load C:\PROGRAM FILES (X86)\BENTLEY\INROADS GROUP V8.11\BIN\CivUstAT.dll, error 126.MDL Loader: Unable to load library (DLL or MDL shared library) CivUstAT
Is there a .cfg file i need to update to get geopak working again?
There are two config files (geopak.cfg and inroadsat.cfg) in your MicroStation /appl directory. You do NOT want them both enabled at the same time.By enabled, I mean that anything with the .cfg extension will be executed when MicroStation is tarted.
If you want to run geopak, then make sure it has a .cfg extension and rename the inroads file to something other than .cfg.
If you want to run inroads, then make sure it has a .cfg extension and rename the geopak file to something other than .cfg.
Derricke
You could put them in a sub folder and add two user config files - One for GEOPAK on one for InRoads and in each, use the %include syntax and point it to the sub-folder and appropriate file.
Unless by the time the UCF file is read, too many other things needing these have had to happen.
