When I try running the cross section labeling tool out of the Corridor Modeling window I get an error
Run-time error '91':
Object variable or With block variable not set
I have the options to "End", "Debug", or "Help"
"Debug" opens VBA editor which is far beoynd my experince to use. "End" closes the processes without starting the labeling tool. "Help" opens a help window which hasn't been very helpful.
How can I get cross section labeler to run? I've restarted multiple times and tried creating a new file and copying in the cross sections to a clean file. Any suggestions?
I'm using V8i, Select series 2.
Here is an xsd.dgn. Please note that this issue is not limited to one dgn in my case. Rather all of the dgn's I have tried show the same error. The error also occurs on other user computers using the same files.
I can confirm the problem with these files. The usual culprits are not at fault. Does this happen with other cross section files (ie cross sections from other chains) with the same gpk?
Yes, this does happen with other cross section files (other chains) with the same gpk.
do all the xs with problems have chain names with the Underscore _ ?
All of our chains have an underscore and this tool has worked in the past using them. To check your thought though, I recreated a chain and profile in the same gpk file using the name 'Cedar' and the error remains.
