When I try running the cross section labeling tool out of the Corridor Modeling window I get an error
Run-time error '91':
Object variable or With block variable not set
I have the options to "End", "Debug", or "Help"
"Debug" opens VBA editor which is far beoynd my experince to use. "End" closes the processes without starting the labeling tool. "Help" opens a help window which hasn't been very helpful.
How can I get cross section labeler to run? I've restarted multiple times and tried creating a new file and copying in the cross sections to a clean file. Any suggestions?
I'm using V8i, Select series 2.
what version of geopak are you using?
Bentley GEOPAK V8i (SELECTseries 2) 08.11.07.536
ok, at this point, i am running out of ideas. i can reproduce the problem with your dataset. I would try recreating the xs in a fresh dgn.
I still get the same error with a fresh dgn.
ok. some of your point labels have the special character "&" and also are very long. could you run a test template with one of the ones we provide and create a new test corridor and see if it works.
i suspect the problem could be that the tool does not like the point names
