MXROAD 08.11.07.427
I was trying to apply levels to a non-tangential master string using extension of crossfall (DESIGN, 134 & 104)
Why does this not work when using a NT alignment but works with a normal alignment?
Is this a known limitation or is it a bug?
Hi Roy
This is a known issue. Depending on the alignment there may be a way to get it to work by applying the crossfall between the points of non-tangent on the master string.
If you load up a genio of your model I can have a look for you.
Jason Walsh
Thanks Jason but I’ve already sorted a workaround. I was just wondering what the problem was as it took me ages trying different things to figure out why it wasn’t working.
I take it this will be fixed in the next release ;-)
