We are having an issue plotting with Power Inroads SS2 open. When Inroads is open and we print, all our text falls on top even though the display shows the text falling under other elements. When we print the same file in just microstation (V8i ss3) this text is plotted the same as the display, honoring the sequence order.
Why is Inroads telling the text to go to the top and ignoring microstations display order? Is there a setting somewhere in Power Inroads to disable/ prevent this from happening?
Thanks in advance.
Trip
Hi Trip
Watch this tread:
communities.bentley.com/.../226704.aspx
Frank
