What is the best way to display the contour levels on a contour plan? I have created a contour plan using both of the following methods but cannot find a suitable way of displaying the contour levels:
Hello Mr. Lennon,
The best way is to create an own style set for contours and display contour model with this style set. In private style set you can define masks, colours, fonts, linetypes etc. You can also use existing MX style set ie. "MfW Contour.pss".
To create own style set go for: Tools>Style Set Editor...
To display model go for: Display>Plan with Style Set...
Best regardsAleksander Zamorski
