I can't seem to get proposed cross section elements to draw on my existing ground cross sections. I run the process and it works through the cross sections but draws nothing. Any solutions? A colleague in another office was able to do it, so I am assuming I have a setup problem.
Assuming you use a different Style and Symbology for your proposed vs. existing sections, do you have them defined and initialized for Cross Sections?
jthdr: I've had the same issues in the past and was curious if you were able to find a solution to the problem regarding your proposed DTM not showing up in your XS even though they process. Thanks!
Check out the following wiki article and see if any of the troubleshooting techniques help.
communities.bentley.com/.../components-do-not-display-when-running-draw-cross-sections-from-surface-command.aspx
Beebe: Your article you linked is helpul for another issue I've had in the past but doesn't address the issue I'm currently having and what I believe jthdr was talking about. The existing ground XS run perfectly fine with the existing tin. They are produced as expected. However when I do the same process with the proposed dtm instead, geopak processes through the XS as expected but no proposed elements actually show up. If I use the proposed tin instead of dtm the proposed linework shows up. Unfortunately nothing shows up for the dtm. I've had no luck finding a solution. Thank you!
maybe you can post your dataset for us to look at. You would want to include all files necessary to reproduce the issue.
