I can't seem to get proposed cross section elements to draw on my existing ground cross sections. I run the process and it works through the cross sections but draws nothing. Any solutions? A colleague in another office was able to do it, so I am assuming I have a setup problem.
What files would you need? TIN, DTM, gpk, chain and profile input files?? Let me know and I'll see if I can get them to you. How would I get them to you?
TIN, DTM, IRD, RDP, ALG, GPK, DGN, the entire rddbs folder, XIN,
If I am not mistaken I think this can happen when a user accesses the draw cross section from surfaces tool outside of the Corridor Modeler Dialog. You must have Corridor Modeler Dialog opened and the current project preferences loaded, then use the icon on that Dialog only. I am not for sure if this is your problem, but it is a requirement you must follow.
Chuck
Chuck,
I am having the same issue. Launched Draw Cross Sections from Surfaces as suggested and still no change.
Hmmm, would need to see the data to investigate further. Have you logged a ticket? We will need to likely setup a meeting to look at the problem in your environment. Usually when this happens, it can't find the DTM for some reason when it proceeds to cut the sections.
