I'm cutting cross sections using the Cooridor Modeling tool in Geopak 08.11.07.536. When I cut my sections from the DTM there are places where elements are not showing. The point labels show up, but not the line work. It's not consistant and all levels are on. After creating the surface I displayed my elements and everything is there. I've also displayed the TIN file and there are no gaps in it. Any help on fixing this?
I am getting the same near transition areas that have not been cleaned up. Is this what you have found?
If you are not seeing components in some areas in particular areas where the components are somewhat irregular or non perpendicular to the geometry there is variable to "Use Mesh Algorithm for Cross Section Components" when this is toggled on the components will display more consistently in cross sections.
Variable Manager under - Command Behavior:
Mike LongstreetVermont Agency of TransportationCivil Engineering Technical SupportVTCAD Help
I'm in the middle of creating a DTM right now and cannot check, but I don’t think Variable Manager is implemented in Geopak Corridor Modeler. Using Corridor Modeler (SS2) is like using InRoads without all the little tools that help (like being able to edit a DTM).
