Hello Community!
Can somebody show me the minor option that controls the distance between top of annotation boxes area (Level Datum) and the lowest section string points in drawing stepped long sections.
Thanx!
Take out the datum annotation part. Comment the datum lines and run again the input.
There used to be a bug related to datum in the stepped long sections (at least if using macros).
If it works, then the bug is still around and you may try by moving datum all the way to the bottom.
Have fun,
Val.
I'm trying for first time a stepped profile via linemode and met some problems. I attached my model (DD12), final drawing and inserted a listing of my input file. There are issues in stepped parts of profile for grid, geometry string annotation and line connecting IPs.
Input listing:
DELETE,TMP LONG SECTIONS MODELDELETE,TEMPCREATE,TMP LONG SECTIONS MODELCREATE,TEMP999SUBSSYSDEL,LONG SECTIONS.DPF999NEWDPF,LONG SECTIONS.DPFSUBSSYSDEL,TEMP LONGSECTION.DPF999COPY,DD 12,TMP LONG SECTIONS MODEL060,MX10060,ME10060,MH10060,GK10999 ---> ADDITIONAL STRING FOR K-VAKUECOPY,DD 12,TEMP017,1=NOCU059,1=SCAL,4=8,5=100060,1=GC10999EDIT,TEMP017,1=NOCU020,1=GC10,3=GK10999COPY,TEMP,DD 12017,1=NOCU060,1=GK10999 DRAW,TMP LONG SECTIONS MODEL,DD 12800,1=LAND,4=1,5=3,7=100802,5=0.5,6=0.5,8=0.5,9=15803,1=LONG,3=NOTR,7=500,10=50804,1=STEP,2=WIND,3=MC10,5=,8= ---> MASTER STRING 805,11810826,1=MC10,2=MC10,5=,8= ---> GRID 808,2= ,4=0.18,5=0,6=0.75805,55806,45822,1=FULL,5=-20,6=2 ---> TANGENTS 805,30809,VIPS826,GC10 ---> ORDINATES FOR TANGENT 805,30809,VIPS849,GC10,3=VF809,VTPS849,GC10,3=VF ---> BOXES805,2845,BBL,2=CLP,3=1100,6= 0.0,7= 0.0,9= -1.20,10= 1.2805,3845,BBL,2=CCP,3=1200,6= 0.0,7= 0.0,9= -2.40,10= 1.2805,4845,BBL,2=BLP,3=1300,6= 0.0,7= 0.0,9= -4.40,10= 2.0805,5845,BBL,2=BLP,3=1400,6= 0.0,7= 0.0,9= -6.40,10= 2.0 ---> DISTANCES IN BOX 808,2= 01,4=0.18,5=0,6=0.75805,2806,2846,MH10,2=MC10,3=1100,4=10.,5=,7= 3.,8=,10=0. ---> VERTICAL GEOMETRY IN BOX701,1=GC10,3=1200805,66711,1=GC10,3=VLIN --- gradient805,3806,3808,2= 0 ,4=0.18,5=3,6=0.75721,1=GC10,3=i001,10=90.721,3=VEGP,4=-23.001,i = &VEGP&% --- length of slope 721,1=GC10,3=i002,10=90721,3=VEGL,4=-40001,L = &VEGL& ---> VERTICAL GEOMETRY BESIDE STRING --- length of vertical curve809,VIPS859,GC10,2=D002,7=0,10=0859,3=VECY,4=-68.001,Y = &VECY& --- distance from IP to alignment809,VIPS859,GC10,2=D000,7=0,10=0859,3=VECX,4=-52.001,e = &VECX& --- radius of vertical curve809,VIPS859,GK10,2=D001,7=0,10=0859,3=VECZ,4=-53.001,K = &VECZ& ---> LEVELS IN BOX808,2= C ,4=0.15,5=3,6=0.75805,4806,4809,VTPS846,GC10,3=1300,7=3809,VIPS846,GC10,3=1300,7=3 ---> DISTANCES IN BOX808,2= E3 ,4=0.15,5=3,6=0.75805,5806,5809,VTPS846,GX10,3=1400,7=3809,VIPS846,MV10,3=1400,7=3 ---> TANGENT POINT LABELS808,2= ,4=0.15,5=,6=0.75809,VTPS869,1=GC10,4=-47,10=270809,VIPS869,1=GC10,4=-47,10=270999DISPLAY,999DELETE,TMP LONG SECTIONS MODELFINI
Hope for helpRegardsAleksander Zamorski
