Import contour line as CAD, and generate surface.
Dear Inroad User Community,
How to import file cad of contour line to Inroad and generate surface.
I try many way, but still can't
Thank you.
  • You can import surface from graphics and when you do, you must assign a feature name, a feature style and a feature type. The name can be anything. I recommend "contour" without the quotes. InRoads will add a sequence number as you import multiple contour elements. The style is important for later edit or review. It must make sense in the feature style settings for a surface feature. Finally, the contours must have elevation. If imported as contours, they must be planar. It is also recommended that there be no gaps.
    InRoads has a generate inferred breakline tool that helps eliminate flat areas, but gaps in the contours confuse it.
    Charles (Chuck) Rheault
    CADD Manager
    • MicroStation user since IGDS, InRoads user since TDP.
    • AutoCAD, Land Desktop and Civil 3D, off and on since 1996
