I have a gpk file that has been in use since 2010. I am fairly certain that it was created using v8i and that the only thing we have done is run updates. When I select the project it comes back with the error "Unable to Open Job (j\\job145.gpk). The path where the gpk is located is L:\2009\09100-09199\09145\data. In the user preferences it will not hold the cogo preferences directories. The correct working directory remains in place in the dialog box.
Any suggestions? Is this a corrupt gpk or could updates to GeoPak cause this?
We have no other gpk's that have this problem.
Using MicroStation v8i (ss2) 08.11.07.443
GeoPak v8i (ss2) 08.11.07.536
Unknown said:In the user preferences it will not hold the cogo preferences directories
When I see this symptom, deleting the geopak RSC files usually cures it.
I deleted the .rsc files and the user preferences still will not hold the cogo preferences.
We are having this same issue. Have you been able to find a fix?
Sorry, we haven't found a fix. This project is under construction so it hasn't been a priority. I have put it on the far back burner for now. I would still like to find a fix.
JRiley,
Have you been able to find a fix yet? I am pulling this project off the back burner because we have some R/W final monumentation to do and I would like to not have to duplicate some previous work.
I am still at the same place I was a few months ago?
