For those of you getting started, I wanted to take a moment to point out we have delivered a sample workspace to help you get started. Select the user entitled "Examples". Then for the Project select Bentley-Civil-Imperial or Bentley-Civil-Metric. Finally, select the Interface Bentley-Civil.
I will be hosting a presentation on this workspace at the Bentley LEARNing Conference this May for those interested. Having a robust workspace for this new major release is vital to successful deployment.
Chuck Lawson
Bentley Systems, Inc.
The seam is needed for triangulation ... IE in site modeler a seam was allways used for this purpose. There is another command that could also be used (Break by element).
This however introduces more complexity into the mix as the section of pvmt edge then needs a new feature to be added. In my opinion it adds complexity , maybe other users would be ok with it.. I like to keep it simple. :-)
Michael Barkasi
Application Engineer
Reality Modeling
Chuck
Is there any working DGN files, TIN and GPK for these sample workspaces? I would like to play.
Mike
Mike, no sample data is provided for the workspace as any dgn file and legacy terrain file will work. The idea behind the workspace is to provide an example on how to begin to configure your own workspace to meet your specific design requirements.
Mary, as I understand it, if you have a Bentley Learn subscription, you will be granted access to all presentations online after the conference. HTH.
I received a tip last week from Derricke Gray on a good idea for additional Project Settings - Design Stages. We added 4 new design stages to the Bentley-Civil Example Workspace that will be available in our next release. We added one for Top Mesh Only, Bottom Mesh Only, Linear Features Only, and Components Only. These are all Final design stages and make it a lot easier to get the correct information for machine control and terrain model creations. If you want an updated copy you can get it here. Note the paths are setup for Power GEOPAK, but it works for PG, PI, Inroads and GEOPAK Suite and MX. Just update the files that were delivered with your install after unzipping.
ftp.bentley.com/.../SS3Standards_05_21_2013.zip
Note, as we continue to update our example workspace I will continue to update this thread. Note, the posted link will be good for a few weeks.
