GPK SS3 - uninstall/reinstall or install over old version?
Do I have to uninstall my current version of Geopak, or can I install SS3 side-by-side, or over the top?
  • MaryB,
     We have lots of users running a wide variety of versions of our products, so it's difficult to cover them all here.
    It really depends on what your current version of GEOPAK and MicroStation is.  You can only run one version of MicroStation on a machine and GEOPAK Suite needs MicroStation 397.   So, one option is to install MicroStation 397 and run both GEOPAK Suite SELECT series 2 and SELECT series 3.  Another option is to run your current MicroStation / GEOPAK Suite as is, and use PowerGEOPAK SELECT series 3. With the Power Products, you doen't install MicroStation, as it's all packaged together.   If you are using the beta version of GEOPAK, which was PowerGEOPAK, then you must uninstall prior to install the released version of PowerGEOPAK.
    Lou
    This is a test
  • Does PowerGeopak run with my same Geopak License or do I need a new license?
    How compatible is SS3 with SS2?
    What happens if I install SS3 to check it out but I have colleagues who are still running SS2?
    Will it screw up our existing projects?
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
  • I'd really like to know this as well.  Beyond potential new bugs and issues documented in the release notes, is there any reason that Geopak SS2 MUST be kept around? Which is to say, is there anything that Geopak SS3 does that is documented as being not backwards compatible with SS2?
Reply Children
