been walking through the vertical geometry workshop and have some questions. Might be best to make multiple posts so as not to introduce confusion between questions.
I create a "complex element" best fit profile. Is there a setting that tells the tool "add VC to changes of grade grater than X.X %"?
The profile isnt what I want, so I'd like to be able to edit it.
How do I insert a VC into it? At one location, there is a 2% change of grade that doesnt have a VC.. so I want to insert a VC at that location. How do I do that?
Now, to complicate it a little more, there is a VC close by, so the VC I wish to insert may overlap with the existing VC thats there... but thats a complication. Working out how to add a VC to one of these profiles is the first step.
Hi Gents,
The profile curve between elements will work on a complex element if you select to trim both in the tool settings window before completing the curve creation.
Paul
D-121279 has been logged for the oddity where you must pick a tangent element first.
Robert GarrettSenior Product EngineerBentley Systems Inc.
Answer Verified By: MichaelGilham
FYI - I've experienced the same results with a vertical, or was it horizontal... alignment not trimming as instructed. However my workaround was to drill down into element information and setting the trim settings after the fact.
Thanks for the effort guys.
