I am trying to import a Trimble DC 10.7 file into InRoads Survey with Iroads version 8.11 and Microstation V8i. My understanding is that there should be an option in the Files type drop down box for this, but there is not. I am trying to import conventional survey data from a Trimble TSC3 data collector. Any help would be greatly appreciated. Thank you.
If you do not see the "Trimble DC (*.DC)" filter in the File>Import>Survey Data command, you might not have that filter in your current XIN file. Try opening the civil.xin file in the C:\Program Files (x86)\Bentley\InRoads Group V8.11\Data folder. This XIN has the filter.
Answer Verified By: Phil Dember
Thank you, worked perfectly! The .xin I was using did not have the filter apparently.
The list file types listed in the drop down list is populated by the XIN file. It appears that the delivered XIN includes the entry fo Trimble (*.dc) files.
Can you verify that you have the XIN file loaded that includes this file type?
Hope this helps,
Thomas
