SS2 Template design - which comes first, parametric contraints or rules?
I have designed curb to check the adjacent pavement to determine if the spill or catch curb should be displayed.  I also have turn lanes that disappear and a median widening.  It runs fine from the intersection, but when it gets back into a normal roadway section it's where one side flip flops and I have a catch gutter in a spill scenario.  It continues until the templates change and then works again.  My test is a null point placed horizontally -2 feet from the pavement edge and vertically dropped on design.  My rules tests the vertical value of the null point minus the vertical value of the pavement edge to <= 0.  I know the rules works as I use it in my normal section and under super conditions I see it act accordingly.  I have a feeling it's testing the rule before the parametric constraints are utilized.
