I am creating cross sections using special ditches. Is there a certain number of ditches geopak can use in a run?
I have 82 seperate ditches to use. I tried my run using all of them. Geopak error message said to many to break the run up. How many SD can I use?
I have to make some assumptions based on your post. I am assuming you are using Criteria and you have listed your special ditch names in a define statement? If this is the case, you must limit that line length. I would suggest naming your profiles with very short names, like A,B,C and so on.
