I'm trying to place the civil cell 'Driveway' that was delivered with the product. I'm trying to place it between a roadway and a parking lot. I've created a horizontal and vertical alignment for the driveway. Each tie to the edge of pavement for both entities. The driveway vertical is named and it's my active vertical. However the driveway drapes onto existing ground. Ideas?
Ron,
I believe the driveway is the only cell I didnt originally create for the release. So I could be wrong on this but Try placing it where the driveway does NOT have a profile... IE delete the driveway profile and place the cell.
HTH
Michael Barkasi
Application Engineer
Reality Modeling
Ron, this Civil Cell requires connecting to the existing ground terrain model as you show initially. The profile solution is embedded into the Civil Cell. Once placed, just open the profile view for the driveway centerline, design a new profile, then make the new profile active.
HTH,
Chuck
Sorry to go on a tangent, but how do I set up OpenRoads to find the dgnlibs that were delivered with the product? I just installed the most recent version of PowerGEOPAK SS3 that was released in March 2014. Thanks
Example:
CIVIL_CIVILCELLDGNLIBLIST = $(_USTN_PROJECTDATA)/dgnlib/Civil_Cells/*.dgnlib
Robert GarrettSenior Product EngineerBentley Systems Inc.
