Hello,Is there a way to have a linear feature created from Null Point (Create template) in the output 3D model of corridor?In ss2 we had a chcek box to include Null Point in triangulation or to decide whether to create or not the linear feature from this point.
I had to define my tamplate in the way that CL point is actually a null point and need a linear feature for this null point in output 3D model, just to display it on cross-sections. That seems to be critical to annotate all features offsets.
Thanks.
Adam
Microstation v8i SS3
Inroads v8i SS3
Adam, this is not currently supported in SS3. I actually ran into this the other day. What I found with some help from others was this... You can make an end condition of zero length and toggle off the end condition option to "check for intercept'. To get to an end condition of zero length and edit it, you can use the Active Template mode. I will file a request to see if we can add this request back into the product in a future release.
Answer Verified By: Adam Wieczorek
CR is needed for that.
Best,
OpenRoads Designer 2023 | OpenRail Designer 2023
