Hi Dears,
I am using MX Road V8i Select series 2. I have to make a design for four laning road. I have one Center Line and 2 Median edge for both sides. The problem is how we can show both sides median edge as FRL in L-Section. May kindly be reply if anyone has the solution.
Thanks and Regards
You can transfer centre line level to both median edges using minor option 130. While generating profile for centre line add median edge string to show the levels on profile.
Anil
If you have designed your median edge strings from your centerline, then just use the display associated string option from additional surface menu. If you are using input files use 826 option to draw the strings and 846 to display levels.
regards
Viknesh
