End Condition at Wall
Perhaps I am not searching for the correct terminology, but I am having trouble finding an answer to what I thought would be a common scenario. Or maybe I am going about all wrong. I have a roadway corridor that is in a fill situation just before it gets to the bridge. I would like to have the fill slope terminate at the MSE wall (think of 45 degree wingwalls around the bridge) where it encounters that wall, otherwise just continue to the existing ground as usual. I have created a separate corridor to model the MSE wall, which for right now is just a real simple vertical wall, one foot thick. This wall corridor was setup to have it's own horiz alignment and vertical alignment controlling the top, and the bottom of the wall is set at 5' below the existing ground line (at least for now).
I am not sure if this should be done using the Clipping Options, or maybe the End Condition Exceptions or what.
A little guidance would be helpful!
Ken
Parents Reply Children
