We need to run both Microstation V8i Selectseries1 w/Geopak (Civil Suite) SELECTseries1 AND Microstation V8i Selectseries 2 w/Geopak SELECTseries2. I was able to install Microstation V8i SS1 and SS2 by using the EasyMultiInstall.vbs in their own respective folder under C:\Program Files (x86). Then I installed Geopak SS1 with no problem. However, when installing Geopak SS2, it seems to have deleted Geopak SS1 or at least went on top of it even though I chose to install in a separately different folder than SS1.
I even tried installing SS2 first, then SS1 but same result.
I am running on Win7Pro 64bitWant to install the Geopak SS1 (08.11.07.246) and Geopak SS2 (08.11.07.615)
Thank you and any help is appreciated,Mark
