Changing Null Levels (-999) to Zero level for multiple points in a string
Hi All,
I am using MXRoad SS2.
I was trying to change null levels of few points in a string to zero level.
By using minor option 021/022 I was able to do that, but I can do that for single point at a time.
How to change ALL null levels in a string to zero level on one go. The string is having points with other level also, which I dont want disturb.
Thanks in advance.
Anil
Parents Reply
  • A null level is a special value that MX knows to ignore when creating triangulations, cross sections etc. Say you created a triangulation from a string with four points, and two of the points had null levels (dimension 3 = -999.000). Only two of the points would be included in a triangulation - the two points with the null levels would be ignored.
    So null levels are not "wrong" - and they can be very useful. For example, let's say you surveyed the route of a fence which crossed a ditch - if there was a point on the fence string where it crossed the ditch it should have a null level so that it does not distort the triangulation.
