Geopak Rounding Issues
Hi all, I created a surface model by Corridor and Modeler on a highway interchange project. Now I am facing a rounding issues during creating sheets (Pavement Elevation Detail Sheets and Cross Sections Sheets) from this model. Apparentely, all the numbers are only accuate to three decimals  number from the model. For instance, if the number from COGO is 680.25451, it round to 680.26 instead of 680.25.Because the number from the model shows 680.25500. It seems like the model has limitation of accuracy. I changed the Geopak user preference output accuracy in Geopak, everything looks right in Corridor and Modeler window, but it rounded to 3 decimals when you create surface.  Anyone else has ever met this problem? Is there any setting in Corridor and Modeler we can tune the accuracy of the model? Thank you very much.
