When creating an alignment on powercivil SS3 using the civil tools, object manipulators disappear when the alignment is very long, only manipulators for PI's remain and the ones for radius, lines, etc do not show except for the first few elements. Has anybody seen this?
Juan Solorzano
They should re appear as you zoom in closer to specif geometrc components of the selected alignment
Michael Barkasi
Application Engineer
Reality Modeling
They don't reappear, just on the beginning of the alignment
a little further same zoom, various levels of zoom
They do not appear as zooming in.
Be sure your "Handles" are turned on in the element selector dialog... If they still are not showing up you will need to log a support ticket. (also be certain you are selecting the civil elements...
IE are you working in 2D or 3D... If in 3D a 3d element is created from the Hz using the profile... if this is selected no manipulators appear when the 3d string gets selected...
use tab and also use right click to cycle through elements that may be aligned on top of each other.
Definitely not an issue of handles or 3d, the issue is related with complex element having spiral transitions, a similar alignment with no spiral will show all handles, but one with spiral transitions will show only the handels for the first few curves. Have logged a support ticket.
regards
