I have installed MX Road V8i (Select Series 3) version 08.11.09.493. It has excellent features of 3D views, most powerful open roads, etc.
As i tried to link with PSPAD to run input files by copying the " bnlxInpRunOnce.exe " in the folder C:\Program Files (x86)\Bentley\MX V8i (SELECTSeries 3)\MX\MFW\Exec. After that i have done the PSPAD customisation regularily i did for previous versions of MX Road (please see the attachment .pdf file). When i run the compiler Ctrl+F9 the input file is not running. Till now we are all so much attached to input files running directly from PSPAD itself.
Is the new version of MX Road (Select Series 3) will not support PSPAD custmisation at all ? If so our work flow will be very slow. As of now we are very much used to run the input files from PSPAD. Just like cut off wings ?
Do we need to download any new version of " bnlxInpRunOnce.exe " and " bnlxToolBar.exe " ?
Any ideas please let me know.
An early response is highly appreciated.
Thanks a lot in advance.
with regards
Ramu
The bnlxInpRunOnce.exe and bnlxToolBar.exe and all other VB utilities do not work in MX SelectSeries3 as references to OCX's and DLL's have changed. And you cannot download updates I'm afraid. I'm told it's in the pipeline..
regards
Per Justsen
Per,
I have successfully managed to get this to run input files from the right click menu in explorer but once run it deletes the input file. Any chance you can see if this is something in the code of the file that tells it to delete once run.
Cheers,
Adam
Ups, I'm sorry.
Sometimes the original file is erased since the filename send from PSPAD to the RunInputFile is not always a temporary file. The file is deleted after RunInputFile has finished. I have changed the code and also used the amended version of RunInputFile without any unwanted deletion of input files.
So please try it out but for safety reasons take a copy of the file.
Danish Road Directorate
Thanks Per,
Works great from the windows explorer context menus :-)
To get the input file runner working install the MX Bonus tools for MX v8i SS3 and make the change detailed in the wiki article below.
Setting up Input File Runner for MX v8i SS3
