I am having trouble with some components in my cross sections not displaying. I have check the styles to make sure the display options are correct and they are since I have components of the same style displaying at different stations. Everything seems to be displaying fine in the Roadway Designer Cross Section View. When I go to Update Cross Sections > Components the components I want to display on are able to be selected but then nothing seems to happen when I hit apply. Any thoughts would be appreciated. I have attached some photos.
Do the missing components have vertical sides? If they are constrained as vertical with a 0.0 value, they won't triangulate and therefore show up in the cross sections.
Yes the components have verical sides constrained with a 0.0 value. But the components that are showing up have this constraint too.
Also, one of the components that isn't showing up is a non-trianglulated component with no parent relationship or display rule attached.
Vertical sides are allowed in components, their are not allowed in triangulated surfaces only.
Try to toggle on a variable: Use Mesh Algorithm for Cross Section Components via variable manager. In some cases this helps with displaying components.
... and check if you have all levels on.
Thanks for the suggestions.
All levels are on and I have the Mesh Algorithm variable toggled on as well.
