I posted a similar topic on this forum several weeks ago but no one seemed to have an answer so here I go again. Assume the following work flow:
In an every day working environment the first horizontal alignment created is never the final one that is constructed. There are always multiple revisions to an alignment due to unforeseen issues. Given that, a user will come to a situation where the complex horizontal alignment Horz1 will need to be modified in some way. Two possible scenarios are as follows:
If we look more closly at #2 and what happens when this type of revision is required you see that when new elements are inserted into the complex element and a new complex element is created it takes on a new name, say Horz2. On the surface this is not an issue BUT the vertical alignment of Horz1 is not preserved when Horz2 is created. The new complex element has no defined vertical alignment associated with it.
As you can see there are many implications that result from this, inculding corridor definitions, superelevations, and template drops to name a few.
How can I get around this? If it is not possible to preserve a vertical alignment from one complex element to another then the current version of the software is nothing more than a neat toy to play with on the computer. There would not be any real world project that I could use this version on since, as stated above, there is no project where the first horizontal alignment is the one that is constructed.
Marc
Marc:
First, when you partial delete or trim a vertical, the original is not lost. Perhaps you mean that the name is lost? Even this should not happen, I don;t think. If it is then please explore this as a bug report.
Second, I would suggest that a preferred workflow is to always use Active Profile in corridor defintions and etc. Then you workflow becomes:
Robert GarrettSenior Product EngineerBentley Systems Inc.
Robert,
I am not referring to an edit to a vertical alignment in this workflow. I am referring to an edit requiring a trim/partial delete to a complex horizontal element with a vertical alignment. If I make an edit to a complex horizontal element and need to create a new complex element from these revised parts the new complex horizontal element does not contain the vertial alignment from the original element.
Oh. Sorry. I misunderstood. One of the following should work, but I have not tested.
The new horizontal element does not contain the original elements profile since a new complex element is created in this process.
If I follow the above workflow, which I have not had a chance to test as of yet, will the projected profile be an actual vertical alignment with tangents and parabolic curves or will it be a series of PIs? My guess is, based on past history with the project profile command, it will be a series of PIs. While this may be ok for modeling purposes it does present an issue with reporting and production work as any plan sheet of profiles must show an actual profile alignment. My preference in modeling would also be for the model to be based on a true profile since this is what would be used for construction purposes.
I believe you had recommended this workflow to me when I posted this question before. I still think this is a serious flaw in the current version of the software and wold think it should get more attention from the Bentley staff. If a vertical profile can not be maintained or copied then how can this version be used for any active projects?
Robert, second one works but it may be confusing that few profile models are needed to edit VA. Especially when you deal with more than 1 HA edit.
