GPK SS3 cannot generate existing cross sections
I am starting a new project, and I will need to cut cross sections from my existing ground.
That is not working for me. When I called Support, they told me that Cross Sections from Surfaces does not work in SS3. Is this really so?
Is there another way to generate the existing cross sections (with XS cells) that I need for the rest of my project design?
DO I really need to roll back to SS2? Can I run SS2 and SS3 in parallel? Any tips or tricks I need to know to have them both installed and runable (not running at the same time, just the option to run one or the other without having to install/uninstall/reinstall)?
When will this be fixed? It seems like a pretty large oversight...
Thank you,
MaryB
MSTN 08.11.09.397
GPK 08.11.09.493
