Good afternoon.
I am using Microstation V8I SS3 and I get this annoying pop-up whenever my pointer is selecting certain elements. How can I remove this pop-up?Thank you, I appreciate the help!
It looks like you are running one of the Bentley Civil Products. You might do better asking is the Road and Site Design forum.
This heads up menu is hard coded in our OpenRoads products and cannot be disabled. The only way to disable it is to launch Microstation alone without InRoads/GEOPAK/MX.
These are context sensitive menus offing appropriate options for the selected element, so the content changes depending on the element, the only common option is the first icon which is for properties? They will only appear when running a SELECTseries 3 civil product. If you just want tooltip info on the element or access to the customisable right click menu you don't need to select the item only hover.
Ian
Answer Verified By: Jacquelyn Pettus
Unknown said: This heads up menu is hard coded in our OpenRoads products and cannot be disabled.
Unknown said: I have a coworker who is getting this. We're all using Microstation Ss3 and InRoads Ss2...no OpenRoads...but he's the only one that has this annoying box.
EDIT: Sorry, he IS using IR Ss3.
Is there really no way to disable this?
