I am using SS2.615 and labeler is working erratically. Sometimes it will label the text id sometimes it won't. Rerunning the labeler and its still not labeling the same label. Copies of this text element have been placed multiple times with some working and some not. There doesn't seem to be a specific set of circumstances to get it to fail. I have run this on version .423 and on a seperate machine with .615, both with the same issues.
One thing to look for here is check the vertical spacing of the cross sections themselves. The default value is 500 I believe. It is important to not let the cross sections get any closer than this.
Can I use the same text element multiple times on one cross-section. Say if I want to add some bridge labels and just want to copy the same piece of text around for the label? I haven't tried the 500' vertical spacing, but will if I have to redo the cross-sections.
The text content would need to be unique. Using the same text in multiple places would not be supported as I understand the application.
I am having the same issue as rwatson318. I have NB shapes and SB shapes. When I process the run, ALL of the SB labels plot on the cross sections, but only some of the NB text will plot. I hope there is an answer to this issue soon!
