Someone please refresh my memory- isn't there a way to disable automatic processing of corridors? Every little change that gets made is causing a reprocess and our time is being sucked away...
Hi,try use activate-deactivate rule.Regards, Krzysztof
Answer Verified By: Ian Rosam
try use "activate-deactivate rule" in corridor objects dialog.
Jason,
You probably already have your data set up this way but when I first started using the software I was running into the same thing. A geometric change or simple roadway lane width change would cause all the corridors to be reprocessed.
One way I found to get around some of the more trivial changes was to seperate different parts of the design into different design files. For example, I have one design file with only control lines (HCL/TGL), one with edge of pavvement lines, and one with corridor objects in it. You can reference all these together to use them all in design but doing it this way you can change the geomteric control lines and not have the roadway edge lines or corridors process until you enter that particular design file.
Marc
Yep, exactly what I was looking for. Not the most intuitive, but helping me save time now!
