Hi,does anybody have idea why I can't get xml report in SS3? I use inroads icon to run program. Thanks in advance.
Do you have Read-Write access to the Temp fold specified in the path? Also, which report are you running to produce this error message?
You may also need to check the default location of the XML stylesheets for SS3 to make sure some required files exist in the directory. C:\ProgramData\Bentley\Civil\ReportBrowser\8.11.9\en
Make sure you have the following files:
format.xsl
formatPDF.xsl
raw-xml.xsl
ShowAll.xsl
Hi,my settingd are correct. Please see video attached.I have SS2 release installed as well and xml report command works properly.Regards, Krzysztof
What versions of the product do you have installed on your system? I would like to know the MSTN and IR versions and what type of operating system you have. Do you have your own workspaces for each product version?
I share the same problem. Whenever I try to use Tools/XML Reports on alg geometry with InRoads SS3 I get similar error message (only the xml file differs). Reporting on Civile Geometry with right click menu works fine.
I'd do appreciate any tips that helps.
Adam
Microstation v8i SS3 8.11.09.397
InRoads v8i SS3 8.11.09.494
Windows XP SP3
Best,
OpenRoads Designer 2023 | OpenRail Designer 2023
