(Posted for Be Communities User)
InRoads V8i SS2
MicroStation V08.11.07.443
Receives error message "Error 126" when attempting to launch InRoads from within MicroStation.
Please perform the command line switch. This information can be found in the Read Me document or on the wiki article below:
communities.bentley.com/.../inroads-command-line-switch.aspx
1. This is a typical error message you receive when the InRoads and MicroStation products were installed in an incorrect order. If InRoads is installed before MicroStation (either manually or sometimes a multi-installer package can do this), some necessary CFG files are not written to the correct locations. You can try to verify this by going to C:\Program Files\Bentley\MicroStation V8i (SELECTseries)\MicroStation\config\appl and see if the InRoadsAT.cfg is located in this location. If it is not, then it is possible that this could be the problem. What you would then have to do is uninstall InRoads (you can keep MicroStation installed), and run the installation for InRoads again, where it will write everything to the correct locations.
2. If that InRoadsAT.CFG is in that location, we may need to add the command line switch to the programs executables as Andrea suggested. You can visit the website to learn more about the command line switch:
There are two methods for adding the switch. The first is adding –wsLoad_InRoads_SS2=1 to the MicroStation and InRoads shortcut target (under the shortcut properties) or you can create a CFG in the MicroStation folder C:\Program Filed\Bentley\MicroStation V8i (SELECTseries2)\MicroStation\config\system which contains the following
Load_InRoads_SS2=1
and try to launch InRoads. You should now get InRoads to open without the message and the explorer should appear.
NOTE: This is specific to InRoads V8i SELECTseries2. There is a similar process for SELECTseries3 with some minor modifications to the values.
This didn't work for me. I have added the command line switch to the target path in the InRoads shortcut pinned to the Start menu and still get the same results. I have confirmed that it is also on the Microstation target path. I then added the created InRoadsAT.CFG file in the System folder without and with the command line switch in the taget paths and still get the error pop up. And now I can not uninstall InRoads!
Please help!
Hello Bruce,
What versions of MicroStation and InRoads are you running?
Hello!
Versions MS 08.11.07.443 and IR 08.11.07.494
