(Posted for Be Communities User)
InRoads V8i SS2
MicroStation V08.11.07.443
Receives error message "Error 126" when attempting to launch InRoads from within MicroStation.
Hello Bruce,
Did you get a chance to verify if the Applications menu was added into MicroStation after you ran the command line switch? Are you working in a workspace? Do you by any chance have Geopak or WaterCAD on your system? Please verify that you are in fact launching the proper licensed product. If you need assistance troubleshooting your License Managment Tool, please let me know.
Verify that you installed the products in order of Prerequisite > MicroStation > Geopak (if it's being used) > InRoads. Also, if you have WaterCAD on your system, there is a change that needs to be made. Please see the link below:
communities.bentley.com/.../error-messages-given-when-installing-watercad-ss3-with-inroads-ss2-quot-os-could-not-load-c-program-files-bentley-inroads-group-v8-11-bin-gpkcoreroadat-2-0-dll-error-127-quot-and-quot-mdl-loader-unable-to-load-library-dll-or.aspx
Hi Andrea,
The Applications menu is not being loaded into MicroStation. I am not working in a workspace. I do not have Geopak or WaterCAD. I have confirmed launching InRoads (which results on the opening of MicroStation with the error 126 for InRoads unable to load library <DLL or MDL shared Library> CivUstAT). I had originally loaded InRoads prior to MicroStation (our in-house instructions were wrong), however, I then reinstalled InRoads after MS was loaded. I attempted to uninstall everything and "start from scratch" however I can not uninstall or repair InRoads so I installed the products in the above order.
If you are unable to uninstall the product, you may run the following:
support.microsoft.com/.../program_install_and_uninstall
This will allow you to uninstall the product and reinstall it in the proper order.
Problem solved! Thank you!
