I am working on creating mass diagrams for a large earth moving project. I have earthwork running to include separate approaches and connections by using the add/subtract options within earthwork. There is a multi factor used on all earthened fill. I have the entire project balanced to zero.
When I load the log file into earthworks there is a substantial change in quantities. There appears to be rounding issues that arose from our multi factors that we used. Also, it now is including topsoil quantities (only from the add/subtract quantities) within the mass ordinate.
If I load the log file into earthworks, save it as a new log file without any changes, and reload the newly created log file back into earthworks it makes the same errors. I can continue this process indefinitely. It appears the issues is when earthworks loads and reads the log files. Any help?!
Hello thummel,
I apologize for the confusion, but what version of InRoads/GEOPAK/MX are you running? You may find it under Help > About. What specific commands are you running to produce the error?
MicroStation V8i (SELECTseries 2) - Version 08.11.07.443
Bentley GEOPAK V8i (SLECTseries 2) 08.11.07.427
After creating the earthwork log file by processing cross section end areas I load the log file into earthworks to draw the mass balance. The input for running earthwork is the following:
XSECTION
Earthwork
tolerance = 0.001000
vertical search distance = 500.000000
xs dgn = C:\Users\toddhummel\Desktop\XSec_PRUS85.dgn
Proposed Finish Grade
soil type = Ground
roadway exc mult factor = 1.000000
subsoil exc mult factor = 1.000000
fill mult factor = 1.250000
type = line, line_string
lvname = Ts Line
lvname = Asph F Line
lvname = Asph A Line
lvname = Asph E Line
lvname = Conc A Line
lvname = Aggr A Line
lc = 0
wt = 2
co = 1,65,81,85,162
Proposed Undercut
soil type = BlendedBase
fill mult factor = 1.000000
lvname = Aggr B Line
lvname = Aggr F Line
lvname = Aggr C Line
co = 53,69,117,133
Do not include in mass ordinate
soil type = Topsoil
lvname = T_Tie
lvname = Ts Bottom Line
co = 3,130
soil type = Asphalt
lvname = Asph B Line
lvname = Line
lvname = Aggr D Line
lvname = Conc B Line
lvname = Conc F Line
lvname = Conc C Line
co = 1,17,81-82,85,101,130,146
Existing Ground Line
lvname = Grnd Line Exst
lvname = DTM Void Line Exst
lc = 2,ByLevel
wt = 2,ByLevel
co = 6,ByLevel
Existing Unsuitable Material
lvname = Ts Line Exst
soil type = ExistingAsphalt
lvname = Asph Line Exst
soil type = ExistingAggregate
lvname = Aggr Line Exst
Excavation Limit
type = line
co = 3
Ignore Areas
from 309+23.03 R 1 to 310+76.97 R 1
Volume Adjustment
station = 736265
Common Exc volume = 1896
Fill volume = 1642
Fill volume = 822
Common Exc volume = 1147
station = 739000
Fill volume = 732
Common Exc volume = 1126
Fill volume = 5202
Common Exc volume = 646
station = 742000
Fill volume = 2842
Common Exc volume = 3689
Common Exc volume = 30448
Fill volume = 3075
station = 753300
Fill volume = 1094
Common Exc volume = 1646
Fill volume = 940
Common Exc volume = 4541
station = 758800
Fill volume = 1499
Fill volume = 833
Common Exc volume = 1358
Common Exc volume = 4470
station = 764150
Common Exc volume = 5188
Fill volume = 28804
Fill volume = 3815
Common Exc volume = 32518
station = 769075
Fill volume = 27703
Common Exc volume = 1200
Fill volume = 1015
Common Exc volume = 109918
Fill volume = 25
Common Exc volume = 11998
Common Exc volume = 12744
Fill volume = 10044
Write Earthwork Shapes
plot param
lv = 1020300510
lvname = Earthwork Shapes 1
co = 1
wt = 0
Stratify Shape Color
combine common exc + subgrade exc + subsoil exc
Calculate Only Between Excavation Limits
End Area Decimal Places = 4
Process Earthwork for Baseline = PRUS85
job number = 001
beg sta = 7330+00.00 R 1
end sta = 7730+00.00 R 1
There are tools within the earthwork dialog for you to do the multiplication factors. Have you tried adjusting those and recalculating the earthwork with the earthwork tool?
I have made efforts in modifying the multi factors. It seems to reprocess the log file, but when I Review Earthwork they original multi factor remains - even if it is deleted.
