(Posted on behalf of Be Communities User)
Bentley Rail Track Suite V08.11.07.615
"Computer specs: Intel Core I5 2400 CPU @3.10ghz 3.30ghz 8Gb RAM GeForce 8400GS HDD 500Gb.
I installed Bentley Railtrack V8i version 08.11.07.615, Everything goes ok during installation, no error or alert messages are shown, but when I try to run Bentley Railtrack or Bentley Railtrack Suite , nothing happens.(The MicroStation Application run well). I tried to run with different users (admin privileges and normal user) on 2 different machines, with no success. No error messages are shown. Windows 7 Professional version 6.1 64 bits, Build 7601 Service Pack 1. What should I do? We bought a copy of the software and cannot use it, there are projects idle because of that. Thanks"
Please verify that you have performed the command line switch. This information can be found in the Read Me document under Knowns Issues for InRoads Group or at the wiki link below:
communities.bentley.com/.../inroads-command-line-switch.aspx
