(Filed on behalf of BE Communities Member)
Are there any tutorials/workflows/videos available relating to intersection design?
Attached is a Powerpoint that is very helpful in learning intersection design. Although the powerpoint uses GEOPAK, the information applies to InRoads users as well since both product use the Roadway Designer.
Additionally, the attached video demonstrates intersection design in InRoads.
Please note, the PowerPoint shown here is a suggested workflow consideration for 08.11.07.xx based Roadway Designer. This approach would not be the recommended approach for 08.11.09.xx based products. The Bentley LEARN Server has some tutorials for the newer intersection design approach with the use of Civil Cells.
