I'm new to GEOPAK. I am trying to cut existing ground cross sections and keep running into the same error. "There are no Cross Section Cell to process with regards to current settings."
I used the Project Manager dialog box to create all the following objects
I created the existing ground surface by importing point data from an ascii file.
I then created the road centerline chain using the cogo manager. It's a very simple chain. Just a straight line from the center of one intersection to the center of another.
Next I created a cross sections patterns drawing and created my pattern lines.
After that I setup the cross sections dialog box as shown below
But I must have missed a step or setting someplace because I always get this dialog box
I am running PowerGEOPAK version 08.11.09.493
On a Dell Precision T3600
Windows 7 Professional 64 bit, 8 GB of Ram.
With Nividia Quadro 600 graphics card.
Any advice would be greatly appreciated.
Jason
Jason,
I am sorry to inform you that this is currently a defect in the version you are running.
What version would you suggest that I download and install?
download and install 08.11.07.615
FYI... we are tracking this problem as D-120640 and D-120337 in our database. They are scheduled to be fixed in the first update of SS3, post 08.11.09.493 (no schedlue for this update right now, but keep watching for updates).
Answer Verified By: Jacquelyn Pettus
D-120337 filed in regards to a problem with the Profile Analysis command located under GEOPAK > ROAD > DTM Tools, open the DTM Menu > Analysis > Profiles
