I'm new to GEOPAK. I am trying to cut existing ground cross sections and keep running into the same error. "There are no Cross Section Cell to process with regards to current settings."
I used the Project Manager dialog box to create all the following objects
I created the existing ground surface by importing point data from an ascii file.
I then created the road centerline chain using the cogo manager. It's a very simple chain. Just a straight line from the center of one intersection to the center of another.
Next I created a cross sections patterns drawing and created my pattern lines.
After that I setup the cross sections dialog box as shown below
But I must have missed a step or setting someplace because I always get this dialog box
I am running PowerGEOPAK version 08.11.09.493
On a Dell Precision T3600
Windows 7 Professional 64 bit, 8 GB of Ram.
With Nividia Quadro 600 graphics card.
Any advice would be greatly appreciated.
Jason
The issue you are describing is not related to this post. It sounds more like you can not display you components in cross section. I would suggest starting a new post and also maybe take a look at the following wiki article.
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/10136.components-do-not-display-when-running-draw-cross-sections-from-surface-command
