Installing Geopak SS3 using SCCM 2012 issue
I hope this is correct location to post this question, if not please let me know.
I am seeing an issue running Geopak SS3 08.11.09.493 after installing the program using SCCM 2012 (Microsoft's System Center Configuration Manager).  For those of you who might not know but SCCM is an automatic way to distribute applications to PC's on a network.
Anyway, this is the only Bentley application that has an issue after the installation completes. MicroStation, InRoads, ProjectWise, Culvertmaster, gINT, View, etc. all work as expected after install using SCCM.  If I install Geopak by double clicking the msi or by using a batch file from a network drive (which is simulating what SCCM does) Geopak works as expected.  I have tried multiple types of installations using SCCM, packages vs applications, and it all comes out the same.  Using the SCCM to install Geopak will give me some VBA errors when trying to run certain pieces of the software.
Is there anyone else out there using SCCM to install Bentley applications?  If so, has the Geopak install been successful?
On a side note, I used SCCM to install Geopak SS2 Refresh and it would mess up the install for a program that was previously installed.  So if a program like HEC-RAS was installed manually by a user and then Geopak SS2 Refresh was installed by SCCM right after that the HEC-RAS install would try to install again when opening Geopak for use.
TIA
Sean
