I am confused how to create cross sections sheets withannotation using Geopak SS3.
Using the Create Cross Section tool the followingPreferences are offered.
Create Cross Sections
Create Cross Section Preferences
Sheet
Sheet – w/o Grid
Stacked – Vertical Axis Only
Stacked-w/Grid and Axis
Stacked-w/Grid Only
Stacked – XS Only
If I select the “Sheet” preference (no Geopak cross sections cells), I am able to create cut sheets but I am not able to Annotate the Cross Sections.
If I select the “Stacked – XS Only” preference (with Geopak cross section cells), I am able to Annotate the Cross Sections but I do not have Sheets.
Is there a way to Annotate the Cross Sections while using the "Sheet" option?
Annotate CrossSections
Preferences
Frame-Design Elevations
Frame-Design Offsets
Frame-Existing Elevations
Object-Feature Name
Object-Off/Elev./Slope
Ultimately I want “Object-Off/Elev./Slope” annotation on “Sheet”.
I must admit. I am embarrassed.
I found the answer.
I did not notice the option to select a model (upper left corner) in Annotate Cross Sections.
I had multiple models and the correct model was not selected.
Answer Verified By: Philip Mashuda
Some of us call that a brain fart. Or, as we get older, a senior moment. We all have bumped into some simple solution that we should have known.
